Setting up an SU
Setting up an SU
Post by Geoff Ryall-Harvey » Thu Aug 29, 2013 1:17 pm
If you're having issues with your SU stumbling/leaning out on acceleration you can either buy a variety of new springs from Burlens (expensive) to try and see which one will slow the rise of the piston due to the vacuum created by WOT.... or buy a bunch of M33 stainless washers for less than a pound each and use them as dashpot weights fitted under the existing spring.
david
Country: france
Region: lot
Re: Setting up an SU
Post by david » Thu Aug 29, 2013 2:45 pm
There is an excellent book by Des Hammill on tuning su's.lots of good ideas that work on tuning the needle to suite your engine..
Post by Geoff Ryall-Harvey » Thu Aug 29, 2013 5:48 pm
I can thoroughly recommend that book - has a great section on how to select a needle to suit your particular application.
Unfortunately I lent it out and never saw it again....
You should only need to mess around with springs and dashpot weights AFTER you've got the right needle.
