Lomax rear brake replacement
hotfoothowell
CSC Membership Number: 1966
Region: Warwickshire
Post by hotfoothowell » Fri Sep 13, 2013 3:26 pm
Just replacing the brake cylinder and brake shoes on the rear wheel of my 1979 2CV6 based Lomax after complete brake failure (on a busy roundabout -an exciting moment!), using all new parts. However, the two central springs which are kept in place with a pin and cap are dead slack, and I'm reluctant to complete further assembly without advice. I have checked them against the originals, and all parts are identical.
I am not sure how the flanged collars on which the shoes pivot, at the bottom of the drum, go in, flange at the top (so that the nuts bear on them), or flange inwards. Either way, doesn't seem to make any difference to the tightness of the springs. Unfortunately, I did not see which way they came apart, and the Haynes Manual doesn't help. Any suggestions, please? Thanks, Patrick
Region: Herts
Re: Lomax rear brake replacement
Post by Paul » Sat Sep 14, 2013 9:00 am
Hi Patrick,
i don'tknow if this will help. but it's the only photo I have and it's of someone else's set-up. I did take some photos of mine for reference some time back, but I can't find them so assume they've been accidently deleted. However, if they do turn up I'll post them. The photos shows the left side rear brake plate assembly.
Rear drum brake plate pict0029 resize.jpg (50.32 KiB) Viewed 16144 times
Regards Paul
Region: Herts
Post by Paul » Sun Sep 15, 2013 9:23 am
Hi Patrick,
Another view that may help. Copied from the 'Maintenance Handbook for Citroen Twins' by John P Richards C.Eng M.I. Mech E. Reproduction is poor as was the source.
Rear brake 2CV.jpg (72.02 KiB) Viewed 16109 times
Regards Paul
hotfoothowell
Post by hotfoothowell » Mon Sep 16, 2013 12:41 pm
Managed to re-fit the col springs on my rear brakes, boy, what a daft design, and what a struggle. Did they make a special tool for this? Patrick
Region: Herts
Post by Paul » Mon Sep 16, 2013 3:45 pm
I usually manage to fit the slotted cap (item 15) with a pair of pliers. I'm pretty sure I've seen a tubular tool that sits on top of the cap; the tool is depressed and turned through 90 deg to engage the steady pin (item 9). A bit fiddly, though, occassionally everything flies apart and you lose the spring. One of the joys of DIY.
Regards Paul
hotfoothowell
Post by hotfoothowell » Mon Sep 16, 2013 5:26 pm
I notice that the spring caps on the front brakes have two holes to engage with circlip pliers or the like - makes a lot of sense. Patrick
hotfoothowell
Post by hotfoothowell » Wed Oct 16, 2013 3:56 pm
Having now replaced all three wheel brake cylinders, along with the brake fluid, I have bled the brakes several times, and although no further air is coming out of the system, the brakes still require two pumps before they activate. Can anyone suggest what I am doing wrong/ not doing, please? Patrick
Colin-gser
CSC Membership Number: 1821
Region: East Sussex
Post by Colin-gser » Wed Oct 16, 2013 5:26 pm
Hi
Have you centred the brake shoes? This needs to be done carefully and could give the symptoms you have assuming pumping the brakes is taking up the 'slack' in the drums before the shoes bite
I made a tool up for this - length of threaded rod welded to an old axle hub nut with an 'arm' between two locknuts, fit brake drum and adjust shoes on eccentric adjusters, take off drum and using tool adjust eccentric flange nuts on shoe so shoes sit centrally then refit drum, torque up and check eccentrics
Before you check that you could check for airlocks in pipes - I use a syringe and rubber hose on bleed nipples to push brake fluid up to master cylinder which usually clears any air better than bleeding
Finally if you have replaced all brake cylinders and any shoes/pads it will seem spongey for a while
Hope this helps
Colin-gser
Region: Herts
Post by Paul » Thu Oct 17, 2013 10:11 am
Patrick,
If it helps for bleeding the brakes again, I 've used a Europat Vizibleed Bleed Aid. The non-return valve meant it was brilliant when I bled the rear brake. No more two people; one on the pedal and the other tightening and slackening the bleed nipple. The job was done in a couple of minutes and no air in the system. See http://www.halfords.com/webapp/wcs/stor ... 55218#tab1
Other than that, I can only agree with Colin-gser's advice.
Regards Paul
hotfoothowell
Post by hotfoothowell » Sun Oct 20, 2013 3:03 pm
Thanks for your input, chaps. Patrick
