Peter Brooks
- CSC Membership Number: 1898
- Region: East Midlands
Post
by Peter Brooks » Tue Mar 25, 2014 3:49 pm
When fitting the little rubber seals onto the ends of the brake pipe which connects the front callipers, should they be flush with the end of the pipe or should the pipe protrube from the seals with the seal resting against the small bulge in the pipe?
I have fitted new seals this am and one side is still weeping through the top of the bolt without any pedal pressure.
Am I m issing something?
callum
Post
by callum » Tue Mar 25, 2014 5:39 pm
The latter. The end of the pipe should protrude from the seal slightly.
Post
by Ken Hanna » Tue Mar 25, 2014 5:52 pm
Peter,
I hope you haven't over-tightened the nut(s).
The recommended torque for those brake pipe union nuts is only 6 lb.ft, lower if the threads are lubricated...
Peter Brooks
Post
by Peter Brooks » Wed Mar 26, 2014 9:44 am
Callum and Ken thank you for your advice.
as I have not got a torque device that will fit the pipe nuts, can I take it that 6lbs of torque is probably about what is described as "just nipping them up" rather than tightening them down?
thanks
Peter
Post
by Ken Hanna » Wed Mar 26, 2014 2:05 pm
Peter,
'just nipping' fits the bill, although it's probably worth noting that since 'torque = force x distance', it's 6
lb.ft. which is the nominal dry torque...
If they've been overtightened, not only is the seal compressed too much, but the pipe can be wedged into the caliper, making removal of the pipe extremely difficult.
Peter Brooks wrote:Callum and Ken thank you for your advice.
thanks
Peter
Peter Brooks
Post
by Peter Brooks » Thu Mar 27, 2014 9:39 am
Once again thank you for your help and advice.
I have ordered a new connecting pipe and will fit it once it arrives, taking great care to just nip it up and avoid over tightening it.
Peter
Peter Brooks
Post
by Peter Brooks » Mon May 19, 2014 2:57 pm
Finally got around to sorting the problem ut this weekend.
When I got the old transfer pipe off I found a fracture just above the bulge.
New pipe fitted, brakes bled and all is well
Once again thanks for the advice
Peter
