Not much use for the inlets, which needs to have bolts in order to permit the manifold 'spider' to be fitted...
Mendip.Wursel wrote:You can buy oversized studs from ECAS specifically for this job if you didn't want to helicoil
Highwaylass wrote:Can I ask you another question, Ken?
On another thread you recommended a 110 main jet for a Solex carb with pancake filter and 2 into 1 exhaust.
I've got a similar set up but a 24/21 carb. Would you still recommend a 110 main jet? I'm getting a lot of popping and banging on the overrun which makes me wonder if things are too rich.
Highwaylass wrote:Thanks, Ken! I don't think I have a preheat tube, the manifold is essentially the 2CV spider with the exhaust arms lopped off.
What would you recommend for the other jet?
I might have to replace the carb but I thought I'd try new jets first.
Highwaylass wrote:Aargh! It is under the carb, in the gap between the body and the manifold. Super-accessible!
