Rocker cover gasket fitting on Lomax
Portuguy
CSC Membership Number: 2004J
Country: Portugal
Region: West Algarve
Post by Portuguy » Tue Dec 02, 2014 10:36 pm
I thought this would be easy with nice new rubber gaskets . Cleaned off the old homemade gasket material , from both surfaces pasted up with red gasket goo , then lined up surfaces and began tightening up the nut , but of course the gasket spreads / slides itself outwards and distorts . Looks like the Lomax rocker covers dont suit rubber style gaskets , or the job requires more patience to allow one surface to dry out a bit before assembling ? Could the rubber type be meant for the original 2cv rocker covers sitting in a groove ? Anyone know the best gasket for Lomax and the tip for fitting ?
Thanks Aidan
tangara
Country: Belgium
Region: south
Re: Rocker cover gasket fitting on Lomax
Post by tangara » Tue Dec 02, 2014 10:50 pm
Lomax rocker covers are not straight. Had a pair few days ago and milled 1 mm by places to get something technically correct. Don't use past but superglue the rubber on the cover (I have an old head even to glue original ones). I act like this for years and never had a leak
Thierry
Portuguy
Country: Portugal
Post by Portuguy » Tue Dec 02, 2014 11:10 pm
Thanks Thierry. , that makes sense . The Surfaces on the covers looked a bit uneven . Superglue idea sounds good . Have cut home made gaskets on the large size and will trim edges when gasket goo has hardened . If that doesnt work will use your superglue method on the rubber gaskets .
Which area in Belgium are you based ?
Regards Aidan
tangara
Country: Belgium
Region: south
Post by tangara » Wed Dec 03, 2014 11:29 pm
My base (house and private workshop) is in the middle of Belgium nearby the river Meuse and beside ,or nearly ,Namur. Agricultural area with lots of interesting small roads to drive kitcars.
Thierry
Jimmy Cooper
CSC Membership Number: 2033
Region: South
Post by Jimmy Cooper » Thu Dec 04, 2014 1:11 am
Thierry,
You don't by any chance get involved with Theremins do you? Wild stab in the dark. If you ask what's a theremin I know you don't! :shock:
tangara
Country: Belgium
Region: south
Post by tangara » Fri Dec 05, 2014 7:06 pm
Is my answer
Thierry
Jimmy Cooper
Region: South
Post by Jimmy Cooper » Fri Dec 05, 2014 7:12 pm
It's an electronic musical instrument and there is a "Thierry" in Belgium who play one very well...........................but he's not you!!!
david
Country: france
Region: lot
Post by david » Fri Dec 05, 2014 7:23 pm
you could always put a strap around the outer surface to prevent the gasket squeezing out -as original metal return..-and remove strap /jubilee clip/s afterwards...
I always had success with silicone sealant applied both sides to clean surfaces -if they are flat of course...
Post by notsmartcar » Fri Dec 05, 2014 10:00 pm
I use 1200 wet and dry resting on some glass then you will see when the aluminium is flat then the super glue sticks to it well and to the rubber gasket Sorted :D
Portuguy
Country: Portugal
Post by Portuguy » Thu Dec 11, 2014 10:33 pm
Thanks David , and Notsmartcar , for your replies , both are useful. Important to flatten surfaces first . Just got a tiny leak of oil spraying out to sort .
Cheers Aidan
