I had issues last year with a refusal to idle. Ended up rebuilding the cylinder heads and that seemed to cure it.
Last weekend I was on the A45 when suddenly the engine started to 'kangaroo.' We limped on for a bit but had no power at all and had to call recovery.
I've replaced the points and condenser and set the timing, also new plugs (gapped correctly) and leads.
I've also changed the primary jet to a 125 based on a previous conversation with Ken. (it's a 21-24 Solex)
Is my first step to change the jet back?
I'm losing heart that this car will ever run properly
