123 ignition / brown coil
meldrew
- CSC Membership Number: 1244j
- Region: West Midlands
My 2cv based special is fitted with 123 electronic ignition with the black Citroen coil, I have a brown Visa coil, can I use this if the black one expires, if not what alternative coils suit?
'It is what you have not done that will torment you'
Re: 123 ignition / brown coil
the brown coil is different in output and will fry things....
don't fit it...
don't fit it...
Wesley
- CSC Membership Number: 2026
- Region: N. E. Lincs
The deciding factor is the primary resistance value. It should be above 3 ohms ( for a 12 volt battery this will draw 4 amps of current which the electronic ignition should be able to cope with) The lower the resistance value the higher the currant will be, simple, yes?
