Evening,
I've just taken on a part built 223 and after some advice on fitting the master cylinder.
Can anyone help with a diagram or explanation of how the pedal box and master cyclinder should be fitted please??
Many thanks
Marc
Brake master cylinder
tibetans
- CSC Membership Number: 1210
- Region: North West
Re: Brake master cylinder
Not sure if you have a copy of the build manual for Lomax - see link below.
http://www.sportsandleisurecars.co.uk/l ... al_pdf.pdf
Richard
Richard
bassmaster
- CSC Membership Number: 2313
- Region: South East
This exactly my situation.
Just taken on a part built Lomax 223.
I have the build manual, which is not the most helpful instruction manual I have ever seen
I am not sure exactly where to position the pedal box, but also I don't have the adapter brackets that are mentioned in the manual
Can anyone help please?
Many thanks
Many thanks
Drg of Pedal box brkt
Regards Rob
Regards Rob
- pedal box 2cv.pdf
- (5.06 KiB) Downloaded 5421 times
bassmaster
Thank you very much Rob. That's very kind of you.I'll get one made up asap.
Just two questions please
1) what is the 16mm o/d tube for?
2) Does this bracket allow enough room in the engine compartment, to enable the original fluid reservoir to still be used?
Many thanks
Doug
Many thanks
Doug
