S U Carb?
- CSC Membership Number: 2093
- Country: Wales
- Region: Powys
S U Carb?
Following the short discussion in the Sale/Wanted section, I have today been offered a 1" SU carb off a Morris Minor.
Seems to be in good nick and I realise it would need rejetting, but does anyone know whether it would be suitable?
1972 MG Midget
MSA Radio: Worcester 1
Re: S U Carb?
Hi.
Are you sure it's only 1"? If it's of a Morris Minor, I'd expect it to be 1 1/4".
I have a 1 1/4" (HS2) fitted to a home made manifold on my 223, and I'm very happy with it. I can't remember which needle I fitted but I'm sure someone else on this forum will come forward with the answer.
I think a number of other members have fitted
1 1/2 carbs (HS4 or HIF4) with good results.
In my opinion, if it is only 1" it won't be big enough.
Hope this helps
Ian
Hope this helps
Ian
- Country: Wales
- Region: Powys
Re: S U Carb?
I might have to check it a bit more carefully!
Which bit do you measure to ascertain the size?
1972 MG Midget
Re: S U Carb?
Measure the diameter at either the manifold or air intake end.
- Country: Wales
- Region: Powys
Re: S U Carb?
Picked the carb up today and can confirm that it is indeed 1.25", and not as I thought originally.
Can anyone confirm that it will fit under the bonnet of a Lomax?
I presume I am going to have to move the coil pack?
Anyone willing to state what needles to start with?
1972 MG Midget
Re: S U Carb?
I'm sorry but I can't help with clearance under the bonnet. Mine's fitted with a Continental bonnet and I'm not sure how the height compares with a standard one.
Mine is fitted with the filter over the starter motor. I had to add a spacer to the standard manifold to allow the jet full stroke for the choke.
Yes, if you're going to fit as per mine, you will have to move the coil.
- Country: Wales
- Region: Powys
Re: S U Carb?
Thanks.hutchii wrote:I'm sorry but I can't help with clearance under the bonnet. Mine's fitted with a Continental bonnet and I'm not sure how the height compares with a standard one.
Can you do a photograph of yours, please?
What jets have you used?
1972 MG Midget
