Reversing light switch
kgnoble
CSC Membership Number: 2079J
Region: Surrey
Post by kgnoble » Fri Feb 03, 2017 7:38 pm
Hello
Has anyone done anything clever in being able to automate the reversing light going on when in reverse? I believe that ECAS have a switch that fits certain gearboxes....but not mine.
I am thinking of a pull switch perhaps linked to the gear selector but I think the theory and practice may not be coincidental!
Any ideas - or is it down to a separate manual switch and warning light
Keith
SILLYCVS
CSC Membership Number: 174
Region: KENT
Re: Reversing light switch
Post by SILLYCVS » Sat Feb 04, 2017 8:40 am
Seen it done with motorcycle stop lamp switch, type with extension spring, or just change rear cover on gearbox with one with boss cast in.
CSC Membership Number: 2093
Country: Wales
Region: Powys
Post by llanigraham » Sat Feb 04, 2017 5:56 pm
This is how mine works;
As the gear change twists and moves it brings the "roller" on the bracket in line with the arm of the switch and pushes it forward, so turning them on.
Don't know where it came from, but it works even if it looks a "bodge"
1972 MG Midget
MSA Radio: Worcester 1
Post by howardjs » Sun Feb 05, 2017 4:21 pm
The switch in the photo looks similar to RS 621-1515. The roller head and the roller arm can be rotated through 90deg.
kgnoble
Region: Surrey
Post by kgnoble » Mon Feb 06, 2017 5:32 pm
Thanks all, for your suggestions. I think I will spec the £18 for the switch and see how I can do it practically on the Burton.
Keith
Fuzzyjohn
CSC Membership Number: 881J
Region: East Coasters
Post by Fuzzyjohn » Wed Feb 08, 2017 10:03 am
Just a thought. Has anyone considered incorporating a "Proximity Switch". I seem to recall that certain industrial (rising spindle ) valves had proximity switches to give remote indication that the valve was either open or closed
cheers JD
