Fuel Sender. Oh no; you idjut!!!!!!!
CSC Membership Number: 2093
Country: Wales
Region: Powys
Re: Fuel Sender. Oh no; you idjut!!!!!!!
Post by llanigraham » Sun Feb 12, 2017 10:19 pm
If you are going to use the tank outlet then I would run a pipe from the sender unit up to the top of the boot then down to below the floor as a breather tube. If you block it off then there will be no breather and the tank could collapse as a vacuum is formed as fuel is pumped out.
1972 MG Midget
MSA Radio: Worcester 1
