Replacing hazard switch on Lomax
tony-morony
CSC Membership Number: 2119
Region: Lincolnshire
Post by tony-morony » Wed Mar 07, 2018 12:44 pm
Hi all. I am hoping to replace the hazard light switch on my Lomax 223 with a non 2cv one. I thought this would be a relatively easy task!
I know where all the wires go on the new switch as it came with a simple wiring diagram. What I don't know is where the seven wires on the Citroen multiplug come from. They are numbered 1-7 and are colour coded but I am struggling to trace them. I must admit that auto-electrickery is not my strong point. Any help would be much appreciated.
Tony
tony-morony
Re: Replacing hazard switch on Lomax
Post by tony-morony » Sun Mar 11, 2018 9:15 pm
Looks like auto-electrickery is no-one's strong point! :|
Colin
CSC Membership Number: 1112
Region: North Wales
Post by Colin » Mon Mar 12, 2018 11:38 am
Hi Tony,
The Haynes 2CV manual has some wiring diagrams which give some indication of where things go.
Colin
Site Admin
Region: UK Wide
Post by administrator » Mon Mar 12, 2018 4:04 pm
The citroen hazard switch is a clever and complicated beast. It allows you to use one flasher unit on switched (indicators) and unswitched(Hazard) circuits.
Replace at your peril.
Post by cmwbob » Mon Mar 12, 2018 5:19 pm
Hope this helps,
as callum says more complicated than std setup but most useful if you can fathom it.
Not sure if colours correspond with your loom but it should give you a good guide where to look
Regards Bob
2cv wiring diag with hazard sw.jpg (92.04 KiB) Viewed 9656 times
kgnoble
CSC Membership Number: 2079J
Region: Surrey
Post by kgnoble » Thu Mar 15, 2018 7:19 am
If you are not getting anywhere with this try:
https://www.ebay.co.uk/itm/Hazard-Flash ... rmvSB=true
it works for me extremely well on my Burton and was very easy to retrofit.
Best wishes
Keith
tony-morony
Post by tony-morony » Mon Mar 19, 2018 10:41 am
Thanks all for your helpful replies. Armed with this info I'm sure I can work something out.
Tony
