Hazard warning lights and indicators
JIMBO
Region: Deux Sevres
Post by JIMBO » Wed Aug 29, 2018 4:45 pm
Can someone help me when I bought my Mehari the indicator lights just stayed on when you used the indicator stalk not winking. I have bought a new unit but I am unsure if it is wired up right. I have a Citroen Haynes manual but even though I follow the diagram nothing seems to work can anyone simplify a diagram which I can understand and also give me some ideas why it may not be working properly. Cheers Ps the wiring was a mess when I got the car.
Re: Hazard warning lights and indicators
Post by howardjs » Wed Aug 29, 2018 6:16 pm
Hi Check out post re Hazard lights on Page 2 March 19 maybe this will answer your question
Post by cmwbob » Wed Aug 29, 2018 7:21 pm
not sure if this is the diagram you have, but may help
2cv wiring diag with hazard sw.jpg (92.04 KiB) Viewed 10176 times
Post by cmwbob » Wed Aug 29, 2018 7:35 pm
the key is the use of a multi contact sw, or if unavailable use a 3 way 12v relay to replicate the additional required sw contacts
Post by cmwbob » Wed Aug 29, 2018 7:46 pm
relay mod thus
hazard sw std single gang add relay.jpg (146.75 KiB) Viewed 10175 times
JIMBO
Region: Deux Sevres
Post by JIMBO » Thu Aug 30, 2018 6:36 am
Thanks Chaps you are stars.
JIMBO
Region: Deux Sevres
Post by JIMBO » Fri Aug 31, 2018 12:50 pm
I contacted an auto electrical enterprise yesterday to buy a 3 gang relay they say there is no such animal.. Back to square one!!!!????
Post by cmwbob » Fri Aug 31, 2018 3:09 pm
Ignore car parts wholesalers, go to elect distributor, or ebay but this is what you want plus a suitable surface mtg base
https://uk.rs-online.com/web/p/non-latc ... s/0345959/
Post by cmwbob » Fri Aug 31, 2018 3:14 pm
or this 4 pole 12vdc item top of list and base at bottom of list
https://www.ebay.co.uk/itm/Europa-Compo ... i0mVyabPJl
JIMBO
Region: Deux Sevres
Post by JIMBO » Fri Aug 31, 2018 5:51 pm
I have a feeling I may need help to sort this lot out once bought!!!!!!! Thanks for the help.
