Electric fuel pump
Joe
Region: Hertfordshire
Electric fuel pump
Post by Joe » Mon Jun 01, 2020 10:56 am
Hi
I am after a bit of advice on fitting an electric fuel pump, I've purchased a pump (with reservations about it over powering the float) I'm unsure of the amount of optimum pressure required in using a Solex carb, I'm in the processing of fitting the pump and it is flooding the carb's, so I'm thinking of restricting the pressure by reducing the voltage to the pump, would like your thoughts on this idea.
Joe
billp
CSC Membership Number: 2138
Region: South Wales
Re: Electric fuel pump
Post by billp » Mon Jun 01, 2020 12:33 pm
Fit an adjustable fuel pressure regulator and set it for 2 - 2.5psi.
Post by howardjs » Mon Jun 01, 2020 1:07 pm
Hi, on no account reduce the voltage as the pump could stall.
As billp says, fit a pressure regulator or filter/regulator such as Filter King
billdavies
CSC Membership Number: 1986
Region: Ayrshire KA7
Post by billdavies » Mon Jun 01, 2020 2:55 pm
Joe,
You don't say which engine or which pump.
When I switched to Moto Guzzi I had flooding problems as the regulator was not up to the job and the pump was a displacement type that keeps shoving fuel forward despite the regulator not requesting it.
Resolved the flow problem by introducing a tee back to the tank...now the carbs get plenty fuel at a usable pressure, controlled by the float...and any surplus returns to the tank. Been working for three years with no problems...there are no moving parts to go wrong.
Billy
Post by QFAD » Sun Jun 07, 2020 11:26 am
Hi Joe,
As discussesd, if you want a simple solution to overcome over pressurisation, opting for the return pipe back to the tank works well. I also run a big block Guzzi engine (fuelled via a FACET 4 psi electric fuel pump) and use such a return system.
However one slight difference is I have a restriction in the return line to 'encourage' fuel into the float bowls. My fuel lines are 8mm ID and the restriction is 4mm ID. So far no issues.
The Facet pumps are continuous pressure pumps with no internal bypass or electrical cut out as per an SU electric fuel pumps. The SU is a very good pump, but a bit pricy so depends on your wallet...
PS of course if you are running a 2CV engine then stick to the original mech pump - the are pretty reliable, and if you do suffer from having to crank the engine to prime this pump each time you start the engine then fit a non return valve before the pump.
There is a lot of info in previous threads, so do a search - Ken Hanna has given good advice on this and on other issues.
Post by Jack602 » Sun Jun 07, 2020 6:56 pm
To add to Steve's comments, I use a mechanical fuel pump with hand primer from Dee franzose, where Pembleton remained unused for a few weeks at a time during shutdown I found that car started straight away after a couple of pumps of the primer.
I was able to adjust fuel pressure by varying thickness of pump to block gasket.
Hope this helps.
Pembleton Super Sport
Joe
Post by Joe » Thu Jun 11, 2020 6:51 pm
After a few teething problems car running sweetly, but yet to do a journey, I went the mechanical regulator route although may switch back to the original pump, although fitted a new carb so that could be the reason it is running so well, running the pump at 2psi at present will do a 15 mile run up the motorway in the next couple of days to try it all out.
I've had my Lomax for 14 years next month, I have a R1100 Bmw engine in my garage with fuel injection which I was going to fit still not sure.
Joe
Happy driving
