Oil Temp. Gauge
DaveWard
CSC Membership Number: 2223
Region: East Mids
Oil Temp. Gauge
Post by DaveWard » Mon Jul 11, 2022 3:35 pm
Hi Guys ........All Warm Enough ??
Just a quick one. I'm looking to fit an oil temp. gauge to my BRA and was wondering how or where to access the oil circuit to fit the sensor. I may have to follow up with an additional oil cooler but have heard that fitting an OVERSIZED oil-filter is a good bet for adding more cooling surface ??
Any help or advice would be much appreciated.
Dave
CSC1540
CSC Membership Number: 1540
Region: NORTH WEST
Re: Oil Temp. Gauge
Post by CSC1540 » Mon Jul 11, 2022 4:42 pm
Hi Dave , I don't have a oil temp gauge nor a larger oil filter , but I do have a larger oil cooler which based on oil pressure seems to be doing a good job
Ray
CSC Membership Number: 2130
Region: Yorkshire
Re: Oil Temp. Gauge
Post by Jack602 » Mon Jul 11, 2022 7:14 pm
Dave,
I have both the larger oil filter & a oil temperature gauge.
I drilled & tapped the 2cv oil filter housing out to 3/4" unf & hade a stub by drilling a length of 3/4" unf threaded rod.
Then you can use a readily available (inexpensive) oil filter sandwich gauge adaptor for this thread and have a large choice of filters.
I use a Ford Fiesta filter (small) in the winter and a VW Passat 1.9 (large) in the summer.
Plenty of room on a Pembleton, you will need to check for clearance on your 2CV chassis.
Pembleton Supersport 602cc
oil filter adaptor & large and small filters.jpg (339.4 KiB) Viewed 42596 times
CSC Membership Number: 2205
Country: United Kingdom
Region: Cumbria
Re: Oil Temp. Gauge
Post by Davidm » Mon Jul 11, 2022 8:06 pm
Dave
I suggest fitting a temperature gauge before modifying for extra cooling either in a sandwich plate like in a preceding photo or use a sender in the sump plug. I have a pembleton with 2cv engine, the std. 2cv oil filter and standard oil cooler (with fan removed of course) and find the engine usually runs a little cooler than ideal - about 60C rising to 80C in hot weather and up long hills.
I installed a sandwich plate between the filter and crankcase but had a bad experience with a cheap electronic sender and gauge. The system gave a reading about 10C high and then failed after 3 months. I drilled the electrics out of the sender and fitted a capillary gauge. This is accurate to 2C and has worked fine for about 2 years so far. The one I bought is like this -
https://www.ebay.co.uk/itm/313927748151 ... Sw4btiPEQe
- but you can get capillary gauges specifically for cars.
Personally I would avoid a larger oil filter because with extra oil it will take longer for the oil to warm up (and cool) and I have found my engine to be usually a little over-cooled.
Region: Yorkshire
Re: Oil Temp. Gauge
Post by Jack602 » Mon Jul 11, 2022 8:31 pm
Yes, you have to watch for over cooling, hence the smaller filter in winter, I also cover the oil cooler with tank/duct tape in the winter and only remove once longer summer trips arrive, this year tape I took tape off in June!
Pembleton SuperSport
Tank tape oil cooler March 2019.jpg (130.36 KiB) Viewed 42592 times
Region: Yorkshire
Re: Oil Temp. Gauge
Post by Jack602 » Tue Jul 12, 2022 12:14 pm
I also have the latest Burton finned rocker boxes, these lowered oil temp by 10 degree C in any given conditions, I think I now have enough headway for a 650cc kit.
Pembleton SuperSport 602cc
Burton Rocker boxes April 2022.jpg (179.14 KiB) Viewed 42584 times
DaveWard
Region: East Mids
Re: Oil Temp. Gauge
Post by DaveWard » Tue Jul 12, 2022 7:18 pm
Thanks guys, I'll study your info and pictures . Once I have a temp. gauge fitted I'll get a better idea how to proceed .
Again many thanks to ALL
Dave Ward
Re: Oil Temp. Gauge
Post by howardjs » Tue Jul 12, 2022 10:27 pm
The more you know, the more you worry! Fit aluminium rocker covers to dissipate the heat away from the barrels and just fit a pressure gauge to warn you of impending doom!! I just have the standard cooler and filter, not seized up yet... Good job I'm leaning on a wooden desk!
Alternatively, If you really do need to know when the oil is about to catch fire...I have seen a very nice double temp gauge with sensors attached to the spark plugs... The problem with the car type oil temp sender is it's size which makes it hade to fit without sticking out somewhere.
1 front.JPG (37.44 KiB) Viewed 42566 times
Region: Yorkshire
Re: Oil Temp. Gauge
Post by Jack602 » Tue Jul 12, 2022 11:51 pm
Howard,
The extra senders tuck away neatly on my car, using a standard adaptor flange.
The three senders are oil pressure, supplementary 30psi oil pressure warning light (to warn you before it is too late!) and temp sender.
Oil adaptor in place (2).jpg (228.35 KiB) Viewed 42560 times
Region: Cumbria
Re: Oil Temp. Gauge
Post by Davidm » Wed Jul 13, 2022 12:26 pm
DaveWard wrote: ↑
Dave Ward
Dave
If you can protect a sender in the sump plug from weather and damage it is an easy compact installation. Like this :-
https://www.ebay.co.uk/itm/283301356009 ... a0QAvD_BwE
I too fitted Burton aluminium finned rocker box covers which reduced oil temperature generally by around 6C.
