My 223 has a 2 into 1 exhaust system with flared ends on the downpipes and Y piece.
The joints are sealed with sealing rings, but one has disintegrated!
The pipes are 38mm OD, with 47mm OD flare.
The 1 remaining ring is approximately 50mm OD, 38mm ID and a double conical profile 7mm thick
Local motor factors only provide seals by application, but do not recognise a Lomax!
Can anyone advise where sealing rings that will fit can be sourced?
223 Exhaust downpipe sealing rings
- CSC Membership Number: 2163
- Region: Essex
- CSC Membership Number: 1211
Re: 223 Exhaust downpipe sealing rings
I use a firm on ebay called,,,, Every exhaust part. I’m sure they will be able to help
