Alternator Not Charging Question
CSC Membership Number: 1983
Region: UK
Post by Mendip.Wursel » Sat Apr 02, 2016 7:09 pm
Hello
I have been fiddling about with alternators on my Lomax and accidentally making things spark etc and now nothing seems to be charging.
1 - The ampere seems to suggest there is a small charge going into the battery on start-up but then a fuse blows, and then no charge to battery. Any idea's why this is happening?
2 - How can I test if the alternator is working, if I put a 12v volt meter across the alternator contacts when spinning it shows no change. I have tried this on two alternators.
3 - I had the old 2CV voltage regulator on the car which I tried swapping with a modern electronic sealed unit. The new regulator says in the instructions.... 1 Positive; 2 Negative; 3 Field Exciter. How do I know which wires are which from the old regulator, as nothing on old regulator to say which wire is which. With new regulator connected I do not seem to be blowing fuses, but only minimal movement on the ampere meter needle. Having said that I may have the wires wrongly connected.
As you can imagine I have got myself in a right pickle with this .... I never was that good on electrics.
Many Thanks
Kevin
Re: Alternator Not Charging Question
Post by Lomax76 » Sat Apr 02, 2016 11:00 pm
Hello,
I will think that a voltmeter on the batterie should tell you if the regulateur is charging. With some rev on must be around 14Volts..
Post by Geoff Ryall-Harvey » Sun Apr 03, 2016 10:17 am
See here (the first diagram has the Citroen colour codes);
http://2cvstuff.com/Files/Wiring/Wiring%20Post%2081.pdf
Or;
Region: UK
Post by Mendip.Wursel » Sun Apr 03, 2016 6:32 pm
Thanks ..... very useful information
namster
Region: devon
Post by namster » Tue Apr 05, 2016 6:45 pm
I had issues with mine too. Tried new brushes, even sourced a good spare to no avail. In the end I found it was the connection at the ignition. It was scotch locked and was a pretty dire connection.
Ended up basically rewiring the lot as the deeper I delved, the more dubious I found the whole wiring!
