Door on Lomax 223
Venture
- CSC Membership Number: 2064j
- Region: North wales
Door on Lomax 223
Has any one made doors in their Lomax 223 is it easy or a pain to do we were out doing the welsh national rally CMC done 180miles only problem was getting Jean to get out all the time for the clues she said wouldn't be great if we had doors so I said I ask regards Dave & jean
Peter Brooks
- CSC Membership Number: 1898
- Region: East Midlands
Re: Door on Lomax 223
My 243 came with factory fitted doors. I still find it easier to climb in, whilst my better half prefers the more ladylike use of the door.
I think one of the problems with doors is that they restrict the type of exhaust system which can be used as they obviously have to run below the door level so an upswept pipe or a higher level pipe is out of the question as they prevent the door opening
In addition, with mine I have found that it is very easy to ground the silencer when cornering two up.
I also enclosed the "rear seating or boot space" with a back and lid as it was not secure so I never felt happy leaving anything in it.
patrickhowell
- Region: Warwickshire
Another problem with the Lomax 223 with doors is where to put the spare wheel. It won't fit neatly into the boot, and if side-mounted, would interfere with door opening. The only solution seems to be to sit it on a luggage rack on top of the rear turtle deck. Anybody got a better idea?
It does indeed interfere with the opening angle! For what its worth, i didn't find it at all an issue!
The doors are still super useful and the spare wheel only limited it by a small amount. Due to the length of my legs i had to get in and rest on the seat back, then shimmy down anyway, so wasn't a problem.
