Page 1 of 2
Electronic ignition
Posted: Sun Jun 17, 2018 4:56 pm
by Citron Presse
Electronic ignition; is it worth fitting?
Re: Electronic ignition
Posted: Mon Jun 18, 2018 7:17 pm
by howardjs
YES
Posted: Tue Jun 19, 2018 10:04 am
by administrator
depends...
If it's a total points replacement system like 123, then once fitted, it can be ignored thereafter. I've not touched mine since fitting it 12 years ago.
If it's a points-assisted system like Boyer Bransen, then it does improve starting and fuel efficiency, but will suffer from points cam wear and will need adjusted from time to time.
I have both, although I consider the 123 to be the superior solution.
Posted: Tue Jun 19, 2018 7:50 pm
by Rob Bryant
I have a 123 unit fitted now for three years,
Starts and runs better since, and it is maintenance free, ( the main reason I fitted it)
Last year I treated the car to Iridium spark plugs, now these make a real difference when the engine is started from cold.
I would love to fit the new 123 unit with adjustable timing and passcode immobilizer via a bluetooth connection, but I cannot justify the cost.....yet.
Rob
Posted: Sun Jul 01, 2018 9:22 pm
by yesnosorry
I agree with you Guys
123 ignition fit it & forget it.
Lester
Posted: Sat Jul 07, 2018 9:31 pm
by meldrew
I have 123 on my Diane but need a new coil. Any advice on a more reliable coil than the standard black coil, as I have fitted one of these new and after 6 months the engine will not start when hot.
Posted: Sun Jul 08, 2018 4:44 pm
by Lomax76
I am using "Accel super coil yellow" So fare so good but needs 8.8mm silicone racing wires sold normally together as a package.
Posted: Wed Jul 11, 2018 7:38 pm
by kawlomax223
My Lomax 223 had a Boyer Bransden fitted and ran well. However, have just fitted a Lumenition Optronic system to improve reliability and remove the weak link i.e the contact breaker. Am also using a Boyer Bransden coil which seems to be working well too. It is mounted on the Boyer heat sink which aids cooling. The original coil mounting was on the gearbox top but I’ve relocated the Boyer one to the top bell housing mounting just behind the alternator, which will I believe will also help to keep it cool. ;)
Posted: Thu Jul 12, 2018 5:26 pm
by llanigraham
kawlomax223 wrote: ↑
ImageMy Lomax 223 had a Boyer Bransden fitted and ran well. However, have just fitted a Lumenition Optronic system to improve reliability and remove the weak link i.e the contact breaker. Am also using a Boyer Bransden coil which seems to be working well too. It is mounted on the Boyer heat sink which aids cooling. The original coil mounting was on the gearbox top but I’ve relocated the Boyer one to the top bell housing mounting just behind the alternator, which will I believe will also help to keep it cool. ;)
Be interested to see a photo of how you've mounted the coil there, as there doesn't appear to be room under a Lomax bonnet.
Posted: Fri Jul 13, 2018 9:03 pm
by kawlomax223
There you go. The Boyer Bransden coil is more compact that the regular 2CV one. Small right angled bracket attached to the bell housing top stud.
[imgImage][/img]
