Hi, I have a 26/18 solex carb on my lomax, this is a restoration so no idea if it ever ran properly or not. I've got a huge flat spot at the lower rev range but as soon as the second choke opens everything is fine. The thing is there doesn't appear to be a primary main jet! The secondary main is a 90. The emulsion tube is a 1F2 and the seconday air correction jet is a A22 I think. There isn't any tappings for a jet so its not been removed!
Any thoughts guys?
thanks
solex carb 26/18 main jet
What do you mean "mid life crisis"?
Re: solex carb 26/18 main jet
tonplus,
that's because Solex did quite a good job of hiding the primary main jet on certain versions of the 26/35 carburettor.
You'll find it at the base of the nearside float bowl, with access via that blanking plug with a 12mm hexagonal head.
primary petrol jet position by slcchassis, on Flickr
If your carb is the 18-26 version ( primary venturi before secondary
), a 110 jet is a good place to start for a Lomax with 2 into 1 exhaust, no preheat pipe and a pancake air filter.
Retain both the IF2 & 2AA air corrector jets.
Ah thanks Ken, will have a closer look when I get in tonight. All I have to do now is find a 110 jet!
Will have phone around and see what I can come up with.
Paul,
a pin vice plus one of these?
http://www.ebay.co.uk/itm/1-1mm-DRILL-B ... _500wt_716
A 57 number drill would also be in the right field, it seems...
http://www.csgnetwork.com/drillsizeconvert.html
tonplus wrote:Ah thanks Ken, will have a closer look when I get in tonight. All I have to do now is find a 110 jet!
All sorted, a completely different car!
I used the imperial jet conversion tool of 3/64 of which I purchased 10 at 57p from tool station.
Thanks Ken.
Thanks Ken.
Paul,
isn't that closer to 1.20mm, which might well push the mixture a bit rich?
If it turns out to make the beast too thirsty, you could tap the drilling out and fit a Mikuni jet...
http://www.ebay.co.uk/itm/NEW-PATTERN-S ... _500wt_716
tonplus wrote:All sorted, a completely different car!
I used the imperial jet conversion tool of 3/64 of which I purchased 10 at 57p from tool station..
Thanks Ken.
