Steering Wheel bush connection
Posted: Wed Jul 24, 2019 5:42 pm
Having failed the IVA in my Burton, in part because the MotaLita type steering wheel was unacceptable due to the wood surround and the holes in the spokes, I am discovering that there is not a lot of conformity between manufacturers of steering wheels and bushes.
My present setup is the steering wheel on a quick release boss and secured by three m8( I think) bolts through to the Burton supplied steering column. At the IVA the examiner suggested I should return with the original Dyane steering wheel fitted which would be acceptable.
It doesn't fit! The three holes into the Burton column are symmetrical in an equilateral shape, the Dyane (and Burton confirm the 2cv) have a triangular arrangement but one side of the triangle between the holes is longer than the other two.
I therefore need to find another wheel. Does anyone know if the 2cv arrangement is universally typical, or the Burton arrangement more usual. Should I be able to buy any steering wheel or am I going to get caught out by different manufacturers choosing their own standards for this connection?
Any guidance would be very helpful. I should say that I do not think drilling the holes again in the Dyane wheel is an option, both in terms of room and accuracy and would hate to fail again, because the steering wheel does not turn uniformly lock to lock.
Many thanks in advance
Keith
Keith
