Exhaust bandage
moon monkey
CSC Membership Number: 2213
Region: South East
Exhaust bandage
Post by moon monkey » Tue Apr 06, 2021 4:57 pm
My exhaust headers are rusty, so eventually I plan to replace them with stainless steel or something equally shiny. But until then I quite like the look of the "bandage" style exhaust wrap tape, as a purely cosmetic improvement. I was wondering if insulating the headers would have an adverse effect on air cooling? Do the pipes act as heat-sinks at all?
Re: Exhaust bandage
Post by Jack602 » Tue Apr 06, 2021 5:56 pm
I painted the Citroen manifold with "Granville Cylinder Black" & touch up each Spring.
Pembleton SuperSport
reindeer inn Aug 2020 cropped (2).jpg (184.29 KiB) Viewed 10815 times
motomallett
CSC Membership Number: 2031j
Re: Exhaust bandage
Post by motomallett » Tue Apr 06, 2021 6:26 pm
HI Jack can i purchase a Alternator and fan belt cover like yours regards Roger
Re: Exhaust bandage
Post by Jack602 » Tue Apr 06, 2021 7:18 pm
Roger,
My fan belt cover is a transmission casing from a Honda Dylan scooter.
I purchased mine from a scooter breakers, Black Knight, in Stainforth, Yorkshire, they had several in stock.
Cover France 2019 (2).jpg (143.92 KiB) Viewed 10808 times
motomallett
Re: Exhaust bandage
Post by motomallett » Wed Apr 07, 2021 11:40 am
Thanks Jacks should have known you would have found something adaptable and looking good. regards Roger
kawlomax223
CSC Membership Number: 920
Re: Exhaust bandage
Post by kawlomax223 » Fri Apr 09, 2021 11:27 pm
Hi Jack. Very much like your alternator/belt cover but it appears to obstruct at least 50% of your oil cooler! 🤔
Re: Exhaust bandage
Post by Lomax76 » Mon Apr 19, 2021 7:35 pm
Bonjour,
Back to the subject: Exhaust bandage, This should no be of any arm I will even think it is better, hotter gas will travel faster. I have seen many Lomax and bike with bandage. To conclude from a safety point of view it is better as it will prevent somebody to get burned.
moon monkey wrote: ↑
moon monkey
Region: South East
Re: Exhaust bandage
Post by moon monkey » Sat Apr 24, 2021 2:26 pm
Thanks for that! I hadn't considered the extra efficiency of getting the exhaust out. That's a very interesting point.
Re: Exhaust bandage
Post by Vyv Cox » Wed May 05, 2021 5:46 pm
A couple of points about this query. Stainless steel exhausts do not remain shiny after heating, they need polishing from time to time. Wrapping them causes even stainless exhausts to corrode if left wet.
