INSIDE A DG NITION
Posted: Wed Jun 29, 2022 4:40 pm
Malcolm and myself set off for a southern Lakes tour on our way to the CSC gathering at St. Bees, we never made it! (But a really brilliant do).
We were bowling along the A590 when with no warning my engine cut.
My engine is fitted with a DG Nition unit that has been totally reliable for 0ver 14 years.
After much head scratching and to cut a long story short, there was no spark at the plugs. We changed the coil, plugs, plug caps one by one but still no spark. In the end we removed the DG and fitted the standard points and condenser. The timing was set as best we could by eye. A turn of the key and the engine fired and ran moor or less normally.
On returning home after the rest of the great weekend, I removed the back on the DG marked the position of the Hall Effect transistors, re assembled and connected up a coil and plugs. Then with a 12volt bench power supply connected I waved one of the trigger magnets across the marks and low and behold, 2 perfect and powerful sparks. This was repeated several time with the same perfect results.
Here are some photos... Any Ideas
