Valves on my Bra CV3
Posted: Tue Nov 15, 2022 1:21 pm
by DaveWard
Hi Guys thanks for you reply's re Oil Temperature / cooling / gauge etc. I have had to put that on hold at the moment as I now have a more pressing problem.
Driving along the other day it started to stutter and power dropped considerably. I got it home ...just !
It runs ok in the garage if I keep the revs up but won't idle and back fires some-what into the carb. Spark plugs and ignition seem fine . The inlet and exhaust valve gaps were a bit tight ! Adjusted but no better. I I got a compression tester on the off side head ( 130/140 psi ) but there is steel work obstructing my access to the other head. However I brazed a connection into an old spark-plug to get access ...... showing an iffy 40 psi.
I'm reluctant to take the head off but this sounds like a burnt out valve to me.
Any thought or suggestions would be most welcome
Dave Ward
Re: Valves on my Bra CV3
Posted: Tue Nov 15, 2022 2:19 pm
by billp
Hi Dave, I'd give the carb a good clean out first. Use an air line to blow through the jets(preferably backwards in order to dislodge any particles). In the past I have found mine with all sorts of debris and water in it when having the same problem as you. Then fit an inline fuel filter.
Bill
Posted: Wed Nov 16, 2022 8:46 pm
by Davidm
Dave
What compression do you measure on the offside using the same brazed spark plug connector method you used on the nearside ?
Posted: Sun Nov 20, 2022 3:27 pm
by DaveWard
Thanks both, I've now managed to get a better reading from both cylinders .
Going to try getting an airline onto the cylinders as suggested and if results are good will then move onto the carb
Thanks ]
Dave
Posted: Sun Nov 20, 2022 5:07 pm
Don’t suppose your running on points are you,,, is the coil hot to the touch when it starts to misbehave.
