Suspension Mount Bolts
Posted: Mon Dec 12, 2022 7:41 pm
Hello there, grateful for any pointers on how to rectify a problem I have with rattling front suspension. Noise traced to wobbly front suspension mount bolts. Both sides same problem. The chassis is a 1990s galvo job from 'Wheels' who are no longer with us and therefore can provide no advice. The mount on the chassis comprises a steel tube with a hole threaded the full length in something resembling M14 1.25 pitch (or thereabouts), but it may have been tapped sloppily or they used the wrong tap. The male threads on the OEM bolt do not use the full depth of the threaded hole in the chassis mount - there's about a further 30mm of thread available in the hole, so in theory it would take a bolt 30mm longer. With the tapped threads being sloppy the shoulder on the bolt wobbled & delivered a hammering to the outer 15mm or so of the hole, which, being also tapped (but really should not have been), resulted in the outer part of the hole (which mates with the bolt shoulder) becoming worn & ovalled.
See attached pics.
As with many bodgers no doubt i was proud of my initial low effort zen-like repair. It was quick, easy & stopped the rattling. 1/4" copper pipe tapped with a M14 tap and screwed up the bolt and persuaded over the shoulder. i may have also given the crude copper sleeve, when on the bolt shoulder, a quick shave or sand on the lathe to make it fit the hole, i can't quite remember now. then the bolt was screwed back into the chassis and the copper squashed up , successfully taking up the play. This bodge worked for about 1000/1500 miles before the dreaded rattle returned. The copper on the bolt shoulder in the pic appears threaded only because it has been screwed into a threaded hole - it's still not far off m14 at the shoulder.
I have various ideas for a better class of repair this time around and am dithering as to which one to go for:
[1] i could ream out the outer 15mm of the hole and turn up a brass sleeve - this is a variant on the original bodge but requires me to ream the hole accurately and fully central to the remaining m14 hole, which i'm not convinced i can do without messing up the remaining serviceable female thread.
[2] i could ask an engineering firm to make me up a pair of bolts to the same spec (high tensile), but with the m14 long part 30mm longer, thereby using up all the available thread in the mount hole. (i had considered trying to source some high tensile threaded rod but fear the shouldered part of the bolt is shouldered for good reason and if threaded instead it would just shear.
[3] i could buy a m14 1.25 pitch spark plug repair kit. these come with an M16 tap and threaded inserts about the depth of the shoulder. some of the inserts are heli (which i'd never get out if i needed to) and others are available in copper. pretty sure this would work for a while, but of course the bolt shoulder would be mated into a tapped m14 hole rather than an ideally untapped m14 hole, so not convinced it would be a lasting repair.
[4] cut a wee slot in the out end of the mount hole, screw in the bolt, and weld up the slot. i know this would take up the play but fear the heat may weaken the bolt and i'd never get it out again if it sheared.
All and any pointers gratefully received. thanks very much
See attached pics.
