223 Exhaust downpipe sealing rings
Posted: Wed Jun 14, 2023 4:25 pm
My 223 has a 2 into 1 exhaust system with flared ends on the downpipes and Y piece.
The joints are sealed with sealing rings, but one has disintegrated!
The pipes are 38mm OD, with 47mm OD flare.
The 1 remaining ring is approximately 50mm OD, 38mm ID and a double conical profile 7mm thick
Local motor factors only provide seals by application, but do not recognise a Lomax!
Can anyone advise where sealing rings that will fit can be sourced?
