Pancake air filter
Posted: Fri Oct 04, 2013 12:50 pm
by davidf
Does anyone have a website for suppliers of a thin pancake air filter with the correct oval mounting aperture for the standard Solex 26-35 CSIC Carb, and thin enough to fit in the space between carb and Lomax bonnet?
David Field
01522 753372
Re: Pancake air filter
Posted: Fri Oct 04, 2013 2:28 pm
by david
I would think that's why lomax made the oblong attachment to fix onto the top of the carburetor with a thin hollow section to take a pancake filter underneath it at the rear???
Posted: Fri Oct 04, 2013 6:31 pm
Not difficult to make one.... Araldite or JB Weld or pop rivets if you've no welder.
Posted: Mon Oct 07, 2013 11:36 am
by cscmemsec
I saw, some years ago, an excellent home made version, they had used a 'Ye Old Oak Ham' tin and painted it.
Our own is a pop rivited temporary affair that has been maturing for 25 years!
Regards Carole
Posted: Wed Oct 09, 2013 10:41 pm
by dozergyp
Hi Dave, Re your pancake filter, Try / Der Franzose 2CV Shop / on the web
I have had one from before, Item number 10027 Which fits the Lomax ok
;) ;) Regards John.
Posted: Sat Oct 12, 2013 10:38 am
by trikehound
I found one on ebay that did not have a place for the rubber breather pipe ,so drilled it and fitted a brass plumbing fitting with a tale,works nicely!
