Blackjack avion windscreen or aeroscreen or aeroscuttle
Posted: Sat Feb 22, 2014 7:42 pm
by andrewc
Hello,
I'm hopefully well on the way to buying an Avion, which should be a great car but currently has a slightly unflattering split screen and I'm wondering if anyone knows of any of the original Avion split windscreen / aeroscreens parts being available.
Failing that has anyone had a go at coming up with a mod to use some lexan type motorbike bubble screens, or are there any other options - I have seen the Brooklands screens with the Kimble curved alloy cover which looks good, but I was wondering what other options there are
Thanks,
Andrew
Re: Blackjack avion windscreen or aeroscreen or aeroscuttle
Posted: Sat Feb 22, 2014 11:37 pm
There's nothing available off the shelf. The Kimble screens with the plinth will only fit if you have an AeroScuttle. It's not difficult to make a vee screen in a DuVall style. Depends what your skills are.....
Do you know the chassis number of the Avion you're about to buy. I have a register of all the cars and know many of them.
Posted: Sun Feb 23, 2014 11:57 am
If you used something like this;
You'd just mold the edges to the scuttle shape using a heat gun, fit a rubber seal and bolt it down using fairing bolts.
Posted: Tue Feb 25, 2014 4:35 pm
by Avion100
Andrew,
I am now the proud owner of the Avion construction equipment, and can supply a new perspex screen for either the standard car or the clamshell version.
I have some of the glass for the original vee screen, but unfortunately I can't currently supply the pillars due to manufacturing difficulties.
If I can be of help please give me a call on 07932 084994.
David
