Oil cooler hoses - I've sprung a leak!
Highwaylass
CSC Membership Number: 2024
Region: West Midlands
Post by Highwaylass » Sun Apr 06, 2014 6:36 pm
Hello, I'm new to Lomaxes (but not 2CVs) and may have made a schoolboy error...
I took the oil cooler off to get an easier run at the points box.
Now the joints between the flexy hose and the "stumps" on the engine are weeping.
Should I try nipping the jubilee clips up tighter? One of the stump pipes has already become oval, presumably from being squashed by the clip.
Any advice gratefully received!
Sheila
Re: Oil cooler hoses - I've sprung a leak!
Post by notsmartcar » Sun Apr 06, 2014 10:06 pm
If the jubilee clips have caused the stub to go oval it sounds like the clips,are too large I.e. The flat side of the worm area is too large/flat causing distortion.
SILLYCVS
CSC Membership Number: 174
Region: KENT
Post by SILLYCVS » Mon Apr 07, 2014 8:28 am
I have new adapters in stock if needed
Highwaylass
Post by Highwaylass » Mon Apr 07, 2014 6:28 pm
Thanks, both!
Post by hutchii » Tue Apr 08, 2014 9:03 am
My advice would be to use a proper, correctly sized, "hose clip", the type with a nut and bolt on the outside, rather than a worm clip. The screw mechanism design of a Jubilee type clip makes it almost impossible for the clip to remain round when the sizes get small. The hose clips described, provide a much more unifirm clamp without distorting the hose. Readily available on the net or from stores like Halfords.
IMO they also look much neater too! :)
david
Country: france
Region: lot
Post by david » Tue Apr 08, 2014 2:00 pm
when you consider the pressure -especially at cold start up, unless the jubilee clips are really well on, you might get a hose popping off..not good as it makes a mess of both driveway and engine.
Highwaylass
Post by Highwaylass » Thu Apr 10, 2014 12:53 pm
I'm going to get some hoses made with proper crimped ends. Then all i will have to worry about is the leak from the bottom of the push rod tubes :cry:
Dave Guest
Region: Herts
Post by Dave Guest » Tue Apr 22, 2014 11:05 pm
Hi. I've had the same issue with mine. Sorted it in the end by using two clips on each tube, it not pretty but it works. What I'd like to do is what your going to do, but I've no idea where to get the hoses made up(or the sizes)so any help would be very greatly received.
Cheers Dave
CSC Membership Number: 1983
Region: UK
Post by Mendip.Wursel » Wed Apr 23, 2014 5:30 pm
I've secured my bottom hose with two jubilee clips, and then wired from the clip to a bolt head, so the hose doesn't move under pressure
Post by Geoff Ryall-Harvey » Wed Apr 23, 2014 6:11 pm
Any Tractor repair shop will have facilities to make up hose at a good price. If you take in the fittings they will identify the threads and put on appropriate ends. If you're stuck I will dig out the details for you.
Pay a bit extra and get swivel ends - it will make life much easier.
