L've recently been looking for 2cv rear shockers on ebay. Many of those listed are KYB. One seller suggests visiting their (KYB) website to check compatibility. The site lists 3 year ranges:- 70 - 81, 79 - 90 and 75 - 81. The first and last of these list the same part number, 79 - 90 something different.
As far as I've been able to find out all these year ranges use the same length of shocker.
Can anyone suggest why different ones are listed?
Shock Absorbers
Re: Shock Absorbers
hutchii,
only one word of advice needed regarding those KYB dampers; "avoid".
The damping efficiency of a new set, when tested in a country which uses a vibrating plate setup for testing a vehicle's dampers, is lower than that of worn out Lipmesa/Allinquants.
They may be the correct length and the fitting eyes are the correct diameter, but those are about the only positives...
ken
ken
hutchii wrote:L've recently been looking for 2cv rear shockers on ebay. Many of those listed are KYB. One seller suggests visiting their (KYB) website to check compatibility. The site lists 3 year ranges:- 70 - 81, 79 - 90 and 75 - 81. The first and last of these list the same part number, 79 - 90 something different.
Re: Shock Absorbers
Same advice but would like to get informations about those
CITROEN 2CV6 - ALL MODELS 7/1975-90 GT6-2038 £65.00 GT6-2039 £65.00
They are from
Gaz Performance Shock Absorbers www.gazshocks.com
Thank you
Thierry
They are from
Thank you
Thierry
