Clutch drag
hotfoothowell
CSC Membership Number: 1966
Region: Warwickshire
Clutch drag
Post by hotfoothowell » Tue Jul 09, 2013 8:31 am
My Lomax seems to require several seconds with the clutch pedal depressed before the gears will engage without graunching. This is from hot or cold, but only when the car is at rest, not on the move. Any suggestions, please? Thanks, Patrick
Re: Clutch drag
Post by Ken Hanna » Tue Jul 09, 2013 10:14 am
Patrick,
since there's no (*functional) synchromesh on an A series 1st gear, the trick is to select 2nd gear briefly when at a standstill before moving the gear lever into 1st.
That stops the input shaft spinning and eliminates any graunching... ;)
( * Everything else is present, however there's no synchromesh clip.)
hotfoothowell wrote:My Lomax seems to require several seconds with the clutch pedal depressed before the gears will engage without graunching. This is from hot or cold, but only when the car is at rest, not on the move. Any suggestions, please? Thanks, Patrick
hotfoothowell
Re: Clutch drag
Post by hotfoothowell » Wed Jul 10, 2013 8:26 am
Thanks, Ken, I've learned something new. Patrick
