Oil cooler hoses - I've sprung a leak!
Highwaylass
CSC Membership Number: 2024
Region: West Midlands
Re: Oil cooler hoses - I've sprung a leak!
Post by Highwaylass » Fri Apr 25, 2014 7:34 pm
Pirtek Cambridge did them for me - good blokes!
Dave Guest
Region: Herts
Post by Dave Guest » Sat Apr 26, 2014 7:56 pm
Thanks for the info. I'll give them a ring
Highwaylass
Post by Highwaylass » Sat Apr 26, 2014 8:21 pm
Ask for Kevin :)
Dave Guest
Region: Herts
Post by Dave Guest » Sun Apr 27, 2014 4:42 pm
Many thanks. Just a quick one... I see how the hoses fit the engine but is there some sort of fitting to fit on the spigot on the oil rad also which branch is Kevin at. I greatly appreciate all the help as I've already waisted time and money on the wrong hoses.
Cheers Dave
Post by Geoff Ryall-Harvey » Sun Apr 27, 2014 9:53 pm
Is it the standard 2CV oil cooler or a Mocal unit? I've used plumbing compression fittings on the Citroen cooler after cutting off the original fittings.
Dave Guest
Region: Herts
Post by Dave Guest » Mon Apr 28, 2014 11:03 am
I must learn to read previous posts before posting my own..Cambridge.
I have the standard 2cv cooler with cut off pipe so 10mm plumbing compression fitting does sound like the way to go.
Thanks for the help
Post by howardjs » Mon Apr 28, 2014 11:54 am
Or you can use pneumatic compression fittings they obtainable straight or elbow compression to compression or compression to hose tail or banjo, pretty much anything. just Google Enots they are sold by many air and hydraulic equipment suppliers.
The pictures show 10mm OD elbows connecting chopped off aluminium cooler pipes to 10mm copper central heating pipe.
Snapshot 1 (28-04-2014 11-26).jpg (94 KiB) Viewed 11177 times
Snapshot 1 (28-04-2014 11-27).jpg (87.35 KiB) Viewed 11177 times
Post by Geoff Ryall-Harvey » Mon Apr 28, 2014 7:12 pm
Yes - pneumatic fittings would have a much greater range of adapters and they can be had in brass, nickel or stainless.
max244
Region: kent
Post by max244 » Sun Jul 06, 2014 7:59 am
I had my car cooler upgraded and new pipes and connectors fitted by Kevin at Pirtek Cambridge branch.
Outstanding job. High recommended. Now Max just fly!!!
Thanks for the device
Fabio
