Help please. Short circuit and I cannot find it!
John Sobey
CSC Membership Number: 1782
Region: Cotswold
Post by John Sobey » Thu Apr 24, 2014 6:10 pm
:cry: Any help appreciated for my Lomax project, preferably hands on. Short in the ignition cicuit of my Lomax - I did not do the original wiring! Was OK !!!! Thanks
Re: Help please. Short circuit and I cannot find it!
Post by notsmartcar » Sun Apr 27, 2014 9:51 am
If all else fails disconnect the feed from the ignition switch and put a fresh wire in.
John Sobey
Region: Cotswold
Post by John Sobey » Thu May 01, 2014 8:41 pm
Its the ignition switch feed after the fuse which has gone to earth, so feeds flashers, wipers, oil and brake fluid lights plus fuel guage, ammeter, rev counter? etc. Have tried disconnecting them all but no luck. Will be trying again soon when not so busy! The coil/regulator feeds seem ok, they are before the fuse. I have part visa loom in for the 652 ignition module etc but that was running ok. No problem till I wired up the dash, it ran with all the wires dangling!
Post by Ken Hanna » Fri May 02, 2014 3:46 pm
Ammeter?
Hope that's actually a voltmeter...
John Sobey wrote:Its the ignition switch feed after the fuse which has gone to earth, so feeds flashers, wipers, oil and brake fluid lights plus fuel guage, ammeter, rev counter? etc. Have tried disconnecting them all but no luck. Will be trying again soon when not so busy! The coil/regulator feeds seem ok, they are before the fuse. I have part visa loom in for the 652 ignition module etc but that was running ok. No problem till I wired up the dash, it ran with all the wires dangling!
John Sobey
Region: Cotswold
Post by John Sobey » Fri May 16, 2014 10:24 pm
Yes actually voltmeter. AND YIPPEE, just found it! The only working rev counter I have out of 3 has a short in it, i.e. the +ve feed terminal is going to the case. I have now removed it, put a non working one in to fill the hole and will look into the offending item, time to lever the bezel off..........it is the early type and as I said was modified and working ok. Ho Hum, here we go again.....
