Carburettor Parts - where do the rubber rings go?
Highwaylass
CSC Membership Number: 2024
Region: West Midlands
Post by Highwaylass » Thu May 15, 2014 9:28 am
I have bought a gasket set for my Solex (26/35) as I want to relace the float and needle valve.
It has come with an array of rubber rings, some washers and a plastic collar.
I am making a best guess that the washers go under the needle valve.
Can anyone (Ken?) advise on where the rubber rings go?
Re: Carburettor Parts - where do the rubber rings go?
Post by Ken Hanna » Thu May 15, 2014 6:08 pm
Was it this gasket set?
http://www.ecas2cvparts.co.uk/carb-gask ... p-835.html
It's been a while since I've stripped a carburettor right down, but the only (rubber) O ring I can recall was a tiny one for the accelerator pump nozzle and any plastic/nylon washers were replacement bushes/seals for the spindles, however the later versions of the 26/35 carburettor don't have those seals...
Copper washers were used in three locations originally; under the needle valve, under the cap for the filter (close to the inlet tube) and under the blanking plug for access to the primary petrol jet (on the side of the carburettor, close to the throttle linkage).
Any chance you could put a picture of the bag o' bits up? ;)
Highwaylass wrote:I have bought a gasket set for my Solex (26/35) as I want to relace the float and needle valve.
Highwaylass
Post by Highwaylass » Thu May 15, 2014 10:16 pm
Yes, that's the one, but I have extra rings!
I'm not sure how to post a pic so here is a link to it posted on twitter.
https://twitter.com/highwaylass/status/ ... 5373855744
Post by Ken Hanna » Fri May 16, 2014 8:37 pm
Hi again,
I've had a peep at the photograph of the bits and none the wiser, I'm afraid.
That smallest O ring could be the one for the accelerator pump nozzle, but as for the others?
Maybe keep them safe, just in case I'm suffering from brain fade...
Highwaylass
Post by Highwaylass » Fri May 16, 2014 11:46 pm
Thanks for having a look :)
