I have just given QFAD's head a good decoke - lapped vales and cleaned combustion chambers and pistons (consequence of leaking valve stem seals).
When I fired up the engine (started fine) there was a 'loose tappet' sound which appeared to be coming from the O/S of the engine (I checked the N'S cylinder and all seemed fine). I listened some more and the sound definitely seemed to be coming from the crankcase and not the cylinder head) - I thought cam follower?? Mind you I know sound travelling around an engine can play tricks with you.
Anyhow removed the rocker box and checked the valves - all seemed fine. I then loosened the head and removed each valve train in turn - still the noise persisted (seemed to be a little loose tappet type sound every few rotations of the engine. Finally I removed the head and securing the barrel, held each pushrod in its follower - still the noise persisted?
Before I get too despondent do you folks have any ideas?
