hot stating prob,s
stevet2323
Country: Southern Ireland
Region: south
hot stating prob,s
Post by stevet2323 » Wed Jun 25, 2014 6:03 pm
Hi I am having problems starting my 223 when hot I have checked plugs carb, timing points etc I think I saw some where
this is a common fault with the coil. if so what make of coil is the best one to buy?.
Re: hot stating prob,s
Post by Ken Hanna » Wed Jun 25, 2014 6:47 pm
Steve,
I've got a couple of these in regular use on cars now and they seem fine so far.
They're physically identical to the original oil-filled coils, so fit the original mounting brackets and there's no need to buy different plug leads.
http://www.ecas2cvparts.co.uk/ignition- ... -2165.html
stevet2323 wrote:Hi I am having problems starting my 223 when hot I have checked plugs carb, timing points etc I think I saw some where
SILLYCVS
CSC Membership Number: 174
Region: KENT
Post by SILLYCVS » Thu Jun 26, 2014 8:15 am
Concur with Ken on the dry coils, have several on go at present all customers happy
tangara
Country: Belgium
Region: south
Post by tangara » Thu Jun 26, 2014 7:13 pm
A friend had troubles to restart his hot 2CV , so we put a yellow accel on it as we use offroading and ..... still some troubles ?????
As he restarted the hot engine in a few minuts there was no problem but if he waited ten minuts then no restart !!!!
Hot engine being still, the heat in the heads was increasing and as the valve clearance was a bit too short, there was no compression .
Have a look at your valves gap
Thierry
stevet2323
Region: south
Post by stevet2323 » Sat Jul 05, 2014 10:01 pm
Hi got a new dry coil car is 100% now thanks for your help lads
whitelomax
CSC Membership Number: 021
Region: Bedfordshire
Post by whitelomax » Fri Aug 29, 2014 10:09 pm
I'm wondering if this is fuel vapourisation, thanks to the increased ethanol content in petrol nowadays. This summer, if I have been on a long run in warm weather and stop the car, I know that it will not re-start unless I wait 20 minutes or so for everything to cool down. I have twin motorcycle carbs. close to the pots. I haven't had this problem in previous years. But then in previous years there was no ethanol added to Shell V-Power. This year, there definitely is.
