Jimmy Cooper
- CSC Membership Number: 2033
- Region: South
Post
by howardjs » Mon Nov 24, 2014 12:18 am
Do you think the leak could have been caused by ethanol melting the gasket?
Jimmy Cooper
- Region: South
Post
by Jimmy Cooper » Mon Nov 24, 2014 12:34 am
No, as upon removal the gasket was inspected and found to be spot-on/just like new. I found the three fastening screws had been slightly loose initially so the leak had allowed a bit of rust to form on the gasket seal area. I blocked the tank access hole and used wet 'n' dry to clean up the area. I also countersunk the screw holes very fractionally (de-burred really). Fingers crossed it works. Hope so 'cos that'll give me about half a litre more usable fuel capacity including the filler neck!!!!
trikehound
- Region: southern
Post
by trikehound » Mon Nov 24, 2014 9:18 am
Hi,trying to get the reading right is all a game of luck! I have a friend ,who makes a living ,fixing 2CVs & specials ,he cannot do it Even on his own Avion! So best stick to the knowledge that you have got fuel,even when it says empty!Good Luck!
Post
by Geoff Ryall-Harvey » Mon Nov 24, 2014 6:08 pm
The 2CV sender simply does not work with the long shallow Avion tank. Best carry a length of dowel and dip the tank.
Jimmy Cooper
- Region: South
Post
by Jimmy Cooper » Mon Nov 24, 2014 7:49 pm
The thought did cross my mind for the Lomax after about two hours of 'fishing' yesterday Geoff.
Early Lotus 7's used that method too.
Great conversations I imagine; not about gallons per mile but more like 59 miles to the inch!
The way my luck was running yesterday the end of my fuel dipper stick would splinter off in the tank!!!!!
Jimmy Cooper
- Region: South
Post
by Jimmy Cooper » Tue Nov 25, 2014 9:49 am
That's a great gauge Geoff!!!
My old Ruston Hornsby 5 IP stationary engine had a brass tube with a cork in it. Off the cork stood a vertical rod (like piano wire) that then went through the screwed on filler cap via a small central hole with a bit of white paint on the looped over, non poke your eye out end. Just watch the white section descend; then fill up again.
Efficient and never failed!!!!
Going to have this fitted next w/e. I am assured it'll work by the eBay seller in America with the addition of a switch. Just needs some alteration to the float.............................OK, I'll get my coat!!!! Ha ha
Jimmy Cooper
- Region: South
Post
by Jimmy Cooper » Fri Nov 28, 2014 7:13 pm
UPDATE:-
Totally brimmed the tank AND the filler tube. Fuel sitting just at the height of the newly fitted breather which is about 30mm below the flip- filler cap's underside.
Wet away on business for four days. Came back and checked fuel height. Exactly the same as I left it.
RESULT!!!!!!!
tomnorth
- Region: north east
Post
by tomnorth » Sun Feb 12, 2017 5:33 pm
I am new on this site - just bought a lomax as a pile of bits and had a tank made locally for the three wheel version I am building.
Fitted the sender unit this weekend and it has just dawned on me the sender unit is also the fuel outlet yet the tank has a tapped outlet SO what happens with a 3 wheeler - is the sender outlet simply blocked off?
thanks
Tom
