Rain Gutter
Rain Gutter
Post by QFAD » Thu Nov 27, 2014 2:12 pm
Hi all,
I was wandering how folks prevented rain washing over the scuttles underneath the Brookland screens? I have seen rubber used to blank-off the space beneath the screen, so I am thinking along the lines of some form of beading/edging type arrangement (appreciate suggestions) to deflect the rain. I may even invest in new screens mounted on plinths (John Kimble) as part of the solution.
Thanks in adavnce,
PS I already have a St/St bath plug to let the water out of the cockpit! :lol:
Re: Rain Gutter
Post by Geoff Ryall-Harvey » Thu Nov 27, 2014 3:05 pm
Steve - love the bath plug idea ;-)
I have the John Kimble ones mounted on plinths and that works very well. I also have a canoe spraydeck style tonneau on my Avion which helps a lot.
Back in the day many cars would have a rubber or a leather skirt that went from the bottom of the AeroScreen to the scuttle like this;
That would be very easy to do. Silicon rubber sheet is cheap and easily available on eBay. The bottom of the screen could be drilled and tapped at M3 to secure the rubber. You can make it as high or low as you need and it can be trimmed to fit the curvature of the Lomax scuttle.
Slightly more complex would be to make a fibreglass moulding (or adapt a car spoiler maybe) - this is what has been done with the Buckland;
Still leaves a bit of a gap though....
CSC Membership Number: 1983
Region: UK
Re: Rain Gutter
Post by Mendip.Wursel » Thu Nov 27, 2014 6:14 pm
I've seen people with towels there which they have used for years, if you wanted a cheap option.
Re: Rain Gutter
Post by QFAD » Fri Nov 28, 2014 7:13 pm
Hi Mendip Wursel,
A very practicable solution - but not quite what I had in mind ;)
I will keep looking for a more visually pleasing solution.
Cheers all.
Portuguy
CSC Membership Number: 2004J
Country: Portugal
Region: West Algarve
Re: Rain Gutter
Post by Portuguy » Sat Dec 13, 2014 12:24 am
My rubber aprons are breaking up , but have lasted probably 20 years and are neatly glued to cockpit side of the frames . ( No ,...im not into Rubber Gear !)
Re: Rain Gutter
Post by QFAD » Sat Dec 13, 2014 7:36 pm
Hi Portuguy,
I guess you have had your moneys worth. Also all that sunshine (UV) must wreak havoc with rubber.
I have purchased two screens with plinths fro John Kimble and these will provide the mounting for aluminium strips - to fix a piece between the plinths and two pieces to run down to the mirrors on both sides. I will top with a rubber bead to finish them off; I reckon they will do the job and look good.
Re: Rain Gutter
Post by Geoff Ryall-Harvey » Sat Dec 13, 2014 11:51 pm
Much cheaper to buy them direct from John Kimble.
