Oil Cooler info. Cylinder Cooling fans too!!!
- Jimmy Cooper
- CSC Membership Number: 2033
- Region: South
Just considering a larger oil cooler for my 223 and came across a few at reasonable costs on a certain internet auction site.
But, what pipe outlets size is used on the conventional 2CV one? Size is in BSP I guess?
Thanks in advance.
Thanks in advance.
Re: Oil Cooler pipe union sizes?
Jimmy,
We are talking Citroen here, therefore I think it unlikely you'll find another cooler thread quire like it! M16 x 1.5 is the thread size. If you want some adapters for the the block to flexible rubber pipe give Alan Bradford a ring at Silly CVs. 01634 252987.
Hope this helps.
Ian
Hope this helps.
Ian
- Jimmy Cooper
- Region: South
Ha ha Ian.
I have been working on a Hyundai lately so forgot about "Frenchness"
See here and pick a size:- http://www.ebay.co.uk/itm/121515729255? ... EBIDX%3AIT
- Jimmy Cooper
- Region: South
Still looking at these various sizes. I see a lot use AN-10 inlet/outlet ports,
All part of the pleasure chasing stuff down I guess.
http://www.ebay.co.uk/itm/UNIVERSAL-30R ... 4187a8742f
I have been looing at these, priced from £18 can't be bad with 1/2" bsp ports easy to get fittings
- Jimmy Cooper
- Region: South
My std set-up is as shown here:-
So, a few more rows can't hurt. This at present shows the pipes attached to the cooler with just the pipes pressed-on and jubilee clips for retention. Works well enough.
I'm using a 13 row cooler but bumped up the pipe size to 1" and made them quite long. Makes a big difference in oil capacity.
- Jimmy Cooper
- Region: South
Thanks for the info Geoff. Thirteen eh? Unlucky for some!!!!
Any pictures as I'd like to see the layout ?
Here is a picture sent to me by a fellow member (thanks Aidan)!
Best picture I have at the minute - the cooler is mounted on the firewall in the disturbed air near the driveshafts. The pipes go up over the gearbox.
For getting round tight corners...
Enots 10mm compressed air fittings...
10mm od to 10mm od tube compression elbow part number 36051106
with 10mm central heating or pneumatic copper tube.
The rad fixing bolt is missing in this pic.
- 11.JPG (154.12 KiB) Viewed 21737 times
