Hi Guys,
I'm building 2CV 4x4 and need advice on chassis numbers.
The donor vehicle had riveted on plates, one on the body, one on the chassis, have kept both plates.
The body plate will go back on the body, however, should I rivet the chassis plate on my modified chassis or stamp the numbers into the chassis, near the front off side drive shaft?
Peter
Chassis Number
Re: Chassis Number
If a chassis is unmodified you can use the 8 point rule to re register the vehicle. If the chassis is modified then the vehicle will require an IVA, you can then make up a new 17 digit VIN number. 2CV chassis numbers are on a plate in the middle of the chassis or as per mine, stamped on the offside leg by the drive shaft.
Dave
Dave
Re: Chassis Number
Dave,
Thanks for the feedback.
Peter
Peter
