Hi all.
I'm looking to replace my points etc with electronic ignition. I'm by no means mechanically inclined,so I'm having a professional do it. I'm not after performance boost etc. just a reliable turn of the key and runs, what's the best system to suit.
Thanks in advance
Electronic ignition
Re: Electronic ignition
If you're looking easy to fit then it's 123 Ignition. 10 minutes tops on a Citroen Special with no fan and tinware to remove. Not cheap at between £139 and £189;
http://123ignition.nl/product/2CV.html
If you're looking for cheap then it's Boyer Brandsen at £25;
http://boyerbransden.com/IDunits.html
Either is a good way to go and you shouldn't need an auto-electrician to fit either.
- CSC Membership Number: 1983
- Region: UK
There is also the Lumenition set-up, which I quite like.
