Solex carbs
patrickhowell
Region: Warwickshire
Solex carbs
Post by patrickhowell » Thu Jun 09, 2016 10:40 am
Can someone please help me identify the model of Solex carburettor on my 1975 based 2CV, chassis no.01.JC.9305, engine no. 084068206? The only markings I can see are 12M... and a serial number. It has an oval intake. I'd post a photo, but the website tells me it's too large.
JHS1
Region: Derbyshire
Re: Solex carbs
Post by JHS1 » Thu Jun 09, 2016 3:51 pm
According to my Peter Russek manual, it should be a Solex 34 PCIS 6 but marked 123. There is no mention of a 12M.
JHS1
Region: Derbyshire
Re: Solex carbs
Post by JHS1 » Thu Jun 09, 2016 4:39 pm
Further to above. Russek is wrong. My 76 2cv6 has a 26/35 CSIC SCIC twin choke (hence oval inlet). Haynes has the details right.
patrickhowell
Re: Solex carbs
Post by patrickhowell » Fri Jun 10, 2016 3:36 pm
I sent photos to ECAS, whose information leads to identification as a 24-21. It's not helpful that Solex also seem to use letters as well as numerals (see previous posts) which makes one wonder if we are discussing the same item!
Re: Solex carbs
Post by Ken Hanna » Fri Jun 10, 2016 8:47 pm
Patrick,
are you sure that your engine number doesn't start with '048', which would make it a Dyane or Ami engine? (M28 type, 9.0:1 compression ratio)
A 2CV engine plate starts with '050', denoting an M28/1 engine with 8.5:1 compression ratio.
That probably explains why it's fitted with the 21-24 version of the Solex 26/35 carburettor, which was not introduced on 2CVs until July 1978. :lol:
Since the smaller of the two numbers denotes the diameter of the primary venturi, my preference when distinguishing between the various versions of the 26/35 is to list the primary venturi first, hence 21-24, 18-26 and 21-26 for the one used on 652cc Visa engines.
It seems that there are many cars running around exhibiting 'grandad's axe' syndrome...
ImageEarly version of Solex 26 35 carburettor with 21mm & 24mm venturis. by slcchassis, on Flickr
ImageSolex 26/35 carburettor, later version with 18mm & 26mm venturis by slcchassis, on Flickr
patrickhowell
Re: Solex carbs
Post by patrickhowell » Sat Jun 11, 2016 7:46 am
You are entirely right, sorry, the engine number got transposed, and is 0484068206.I believe it was an Ami 8, though I'm not up on these engines.
'Grandad's axe'? That's a new one to me, even though I am a granddad, and would like to wield one on occasion....Patrick
Duncan Grimmond
Region: N. Yorks
Re: Solex carbs
Post by Duncan Grimmond » Tue Jun 14, 2016 11:10 am
Granda's axe must be similar to Thor's hammer. Been in the family for generations, had 3 new shafts and 4 new heads but it's original...
Jimmy Cooper
CSC Membership Number: 2033
Region: South
Re: Solex carbs
Post by Jimmy Cooper » Mon Jun 20, 2016 9:34 am
Ah, Triggers broom scenario.
https://www.youtube.com/watch?v=BUl6PooveJE
