Even starting in gear with pedal on floor the car moves forward, but once away after a mile or so all is fine again, clutch perfect.
When started in morning cold clutch is perfect., it only happens after standing and still warm.
No oil leaks out of clutch housing, adjustment is spot on, baffled.
I have slipped the clutch to burn any goo off the pressure plate but no improvement.
Any ideas, or is it an engine out job.
