Leaking rocker cover gaskets
Mick Boon
Country: canada
Region: saskatchewan
Post by Mick Boon » Sat Apr 01, 2017 6:26 am
I took my 2CV Lomax 224 for it's first drive yesterday, it went really well but I noticed an oil smell. When I arrived back home I could see lot's of oil had been leaking from the drivers side head gasket, and quite a bit from the other side too. My car came with spare rocker cover gaskets, the original type and new Burton ones, I replaced the gaskets with the Burton gaskets...... I notice that it's still leaking a little bit but it's nowhere near as bad as it was, but I'm not happy with any oil leak .
Is this something I will have to live with or is there a fix ?
Re: Leaking rocker cover gaskets
Post by notsmartcar » Sat Apr 01, 2017 9:12 am
I presume yours has the aluminium valve covers in which case put some wet/dry sandpaper on some glass and rub your covers on it till the contact area is flat
namster
Region: devon
Post by namster » Sat Apr 01, 2017 9:15 am
Hi Mick,
What type of rocker covers do you have?
Are they the standard later 2cv jellymould type?
I've never had a problem with cork gaskets on my early aluminium rocker covers. I think most people use a smear of gasket glue or jointing compound on the rubber gaskets to get a really good seal. Its a bit like a silicone sealant.
Mick Boon
Country: canada
Post by Mick Boon » Sat Apr 01, 2017 1:26 pm
It has the standard jelly mold covers. I will get some gasket goo and try that.
Mick Boon
Country: canada
Post by Mick Boon » Mon Apr 03, 2017 12:31 am
I tightened up the cover nut's a bit and that did the job, no more leaking.
Portuguy
CSC Membership Number: 2004J
Country: Portugal
Region: West Algarve
Re:Double flange rubber gaskets for Lomax covers.??
Post by Portuguy » Thu Oct 12, 2017 8:20 pm
My Rocker gaskets are leaking too.Ive got the Lomax aluminium type covers . I noticed on you tube rocker cover gaskets being fitted to Lomax covers and they had what looked like a double flange on the rubber . I fancy these type gaskets but where can i get them and do they have a name ? I will sand down the covers ive got .
Thanks ,Aidan .
Post by howardjs » Thu Oct 12, 2017 10:24 pm
Try Burton part number A15319
kawlomax223
CSC Membership Number: 920
Region: South West
Post by kawlomax223 » Sun Oct 15, 2017 7:56 pm
Yep, the Burton ones are the business and work really well in my experience. :D
