Electronic ignition
Citron Presse
CSC Membership Number: 2154
Region: West Midlands
Electronic ignition
Post by Citron Presse » Sun Jun 17, 2018 4:56 pm
Electronic ignition; is it worth fitting?
Re: Electronic ignition
Post by howardjs » Mon Jun 18, 2018 7:17 pm
YES
Site Admin
Region: UK Wide
Post by administrator » Tue Jun 19, 2018 10:04 am
depends...
If it's a total points replacement system like 123, then once fitted, it can be ignored thereafter. I've not touched mine since fitting it 12 years ago.
If it's a points-assisted system like Boyer Bransen, then it does improve starting and fuel efficiency, but will suffer from points cam wear and will need adjusted from time to time.
I have both, although I consider the 123 to be the superior solution.
Rob Bryant
CSC Membership Number: 216
Region: Midlands
Post by Rob Bryant » Tue Jun 19, 2018 7:50 pm
I have a 123 unit fitted now for three years,
Starts and runs better since, and it is maintenance free, ( the main reason I fitted it)
Last year I treated the car to Iridium spark plugs, now these make a real difference when the engine is started from cold.
I would love to fit the new 123 unit with adjustable timing and passcode immobilizer via a bluetooth connection, but I cannot justify the cost.....yet.
Rob
yesnosorry
CSC Membership Number: 1998J
Region: Leicestershire
Post by yesnosorry » Sun Jul 01, 2018 9:22 pm
I agree with you Guys
123 ignition fit it & forget it.
Lester
meldrew
CSC Membership Number: 1244j
Post by meldrew » Sat Jul 07, 2018 9:31 pm
I have 123 on my Diane but need a new coil. Any advice on a more reliable coil than the standard black coil, as I have fitted one of these new and after 6 months the engine will not start when hot.
'It is what you have not done that will torment you' :roll:
Lomax76
Region: Normandy
Post by Lomax76 » Sun Jul 08, 2018 4:44 pm
I am using "Accel super coil yellow" So fare so good but needs 8.8mm silicone racing wires sold normally together as a package.
kawlomax223
CSC Membership Number: 920
Region: South West
Post by kawlomax223 » Wed Jul 11, 2018 7:38 pm
My Lomax 223 had a Boyer Bransden fitted and ran well. However, have just fitted a Lumenition Optronic system to improve reliability and remove the weak link i.e the contact breaker. Am also using a Boyer Bransden coil which seems to be working well too. It is mounted on the Boyer heat sink which aids cooling. The original coil mounting was on the gearbox top but I’ve relocated the Boyer one to the top bell housing mounting just behind the alternator, which will I believe will also help to keep it cool. ;)
llanigraham
CSC Membership Number: 2093
Country: Wales
Region: Powys
Post by llanigraham » Thu Jul 12, 2018 5:26 pm
kawlomax223 wrote: ↑
ImageMy Lomax 223 had a Boyer Bransden fitted and ran well. However, have just fitted a Lumenition Optronic system to improve reliability and remove the weak link i.e the contact breaker. Am also using a Boyer Bransden coil which seems to be working well too. It is mounted on the Boyer heat sink which aids cooling. The original coil mounting was on the gearbox top but I’ve relocated the Boyer one to the top bell housing mounting just behind the alternator, which will I believe will also help to keep it cool. ;)
Be interested to see a photo of how you've mounted the coil there, as there doesn't appear to be room under a Lomax bonnet.
1972 MG Midget
MSA Radio: Worcester 1
kawlomax223
Region: South West
Post by kawlomax223 » Fri Jul 13, 2018 9:03 pm
There you go. The Boyer Bransden coil is more compact that the regular 2CV one. Small right angled bracket attached to the bell housing top stud.
[imgImage][/img]
