Stripping Exhaust Bolts
Citron Presse
CSC Membership Number: 2154
Region: West Midlands
Post by Citron Presse » Sun Sep 09, 2018 10:28 am
Anyone have solution to exhaust bolts stripping. I assume it's because the Lomax exhaust is rigidly mounted. , Is putting in a flexible section in the exhaust pipe an option?
Lomax76
Region: Normandy
Re: Stripping Exhaust Bolts
Post by Lomax76 » Fri Sep 14, 2018 12:20 pm
Sorry you have not got an answer, being french I am not sure I got the question! if it is related to removing the exhaust bolt, I think you should proceed opposite of the erection sequence, first slightly unbolt the cylinders to release stress, then proceed with the exhaust. Prior to do this it is best to spray WD40 or the like.
I will not use flexible for the exhaust for the reason it does not look nice and will probably impinge the gas velocity, we don't need that do we?
Citron Presse
Post by Citron Presse » Mon Sep 17, 2018 8:42 pm
My problem is with the bolts stripping over time. I've already had to re-tap the threads on one side and now the other side has gone too.
CSC Membership Number: 2137
Region: Deux Sevres, SW
Post by Vyv Cox » Tue Sep 18, 2018 5:17 pm
How rigidly is your exhaust system fixed? My silencer is on two rubber mounts, like this
There doesn't seem to be a problem with bolts stripping after 3000 miles.
Post by Ken Hanna » Wed Sep 19, 2018 12:45 am
Not quite sure why you're using bolts on the exhaust manifold, since Citroen used studs?
The original M7 studs seem to work just fine on the 2CV race cars...
te="Citron Presse" post_id=6629 time=1537213327 user_id=875]
[/quote]
Citron Presse
Post by Citron Presse » Wed Sep 19, 2018 8:35 am
The studs are stripping the threads in the head. I suspect the head flange may not be parallel with the exhaust flange.
Lomax76
Region: Normandy
Post by Lomax76 » Wed Sep 19, 2018 7:16 pm
Thus we are back to the installation procedure release the stress from the head...
Citron Presse wrote: ↑
