Lomax Incidence of cast rocker cover on cooling
Post by Lomax76 » Sat Nov 23, 2019 9:44 pm
Cooling of a Lomax with no fan is a recurrent topic. I am myself experimenting high temperature in hot summer or in traffic jam even thought everybody is saying this is no problem and the engine is known as being robust I want to preserve it.
This being said I am wondering if the Lomax cast rocker cover being so massiv are counter productive for the heat dissipation. I think I should swap the cover with a thinner one, preferably old type on aluminium. Thought idea welcome.
Re: Lomax Incidence of cast rocker cover on cooling
Post by Jack602 » Sat Nov 23, 2019 10:43 pm
I use the early cast Citroen covers on my 602 engine, they use a different gasket to the pressed covers.
Pembleton Super Sport
Mudguards Aug 2019 small.jpg (66.99 KiB) Viewed 8715 times
Post by Lomax76 » Sun Nov 24, 2019 10:34 am
Look Nice, being thinner might ease the heat transfert and thus provide a better cooling performance.
The gasket must be the same as for the regular cover rocket, is it not?
CSC Membership Number: 2137
Region: Deux Sevres, SW
Post by Vyv Cox » Sun Nov 24, 2019 5:20 pm
The material of construction makes the biggest difference. Aluminium has considerably higher conductivity than steel and the increased thickness makes very little difference. It is also said that the larger internal volume of the cast covers reduces the temperature, although I have some doubts about that.
Post by Lomax76 » Mon Nov 25, 2019 10:31 pm
Thanks for the answers
Actually I think both the thickness and the exchange surface do matter, so I will try the old aluminium cover ASAP.
Post by Jack602 » Tue Nov 26, 2019 6:56 pm
Attached is photo showing the difference between the gasket for the steel cover (upper) and the aluminium cover.
The early gasket (available from ECAS & Der Franzose) seals correctly on my 602 cylinder heads.
Post by Jack602 » Tue Nov 26, 2019 7:18 pm
I find a larger oil filter on a 3/4" unf adaptor (available from Def Franzose) helps by increasing oil capacity.
Pembleton SuperSport
oil filter adaptor.jpg (360.85 KiB) Viewed 8653 times
Post by Lomax76 » Tue Nov 26, 2019 8:00 pm
Thanks for the feedback I found the gasket difference in Burton this is clear. For the larger filter I should explore further. As the engine need to run around 80°c a thermostatic valve might be required for a better preheating phase
From Burton
From Burton
Post by Jack602 » Tue Nov 26, 2019 8:22 pm
I use a smaller oil filter (Ford Fiesta) on the same 3/4" unf adaptor in the winter.
I find with the oil cooler blanked off with Tank tape and using 10/40 oil the engine quickly reaches operating temperature, correct temperature and pressure was maintained on a 70 mile trip last weekend.
Dash with oil gauges small.jpg (44.72 KiB) Viewed 8650 times
Post by Lomax76 » Tue Nov 26, 2019 11:15 pm
Jack,
Thanks again for your time I can see there some solution. However it is worth checking the specification of the filter , the two filter in the pictures have an opening valve @2,5bar Citroen recommend 1,5 bar
Champion C104
Bypass valve pressure : 2,5 bar
KNECHT FILTER - OC 51
https://www.youtube.com/watch?v=fAfObQ9jkHA
