Cant help myself
CSC1540
CSC Membership Number: 1540
Region: NORTH WEST
Cant help myself
Post by CSC1540 » Sun Oct 11, 2020 4:30 pm
Hi all . I am at the `If it ain`t broke don't fix it point` but I just cannot help myself !!
I have had lots of problems recently with my 223 which I went through in a previous message, but I have now fixed my original problems by buying a new 26/35 carburettor from China . I asked them what jets were installed before it arrive they wrote back and said " Main 85 Air 100 " . Although it started out of the box, I changed the primary jet for a 110. The car runs well and accelerates smoothly , but it pops from the exhaust whilst ticking over and crackles on acceleration . I can live with it, but don't want to . There isn`t any adjustment on the mixture screw its all the way in and held with a rubber washer. When changing the primary jet are there any benefits from changing any other jets ?( or should I just leave well enough alone ).
I have already :- Changed the carburettor gaskets, Reset the tappets; Reset the electronic ignition; Checked the compression; Changed the coil;
Thanks Ray
Lomax76
Region: Normandy
Re: Cant help myself
Post by Lomax76 » Sun Oct 11, 2020 7:34 pm
Could be due to the mixture too lean, idle jet to small, thus you should increase the jet or adjust the mixture with idle adjustment mixture screw for a richer mixture.
CSC1540 wrote: ↑
This might be due incorrect position of the primary butterfly, difficult to adjust without proper tools, but I read something about this forum, I need to dig.
CSC1540 wrote: ↑
CSC1540
Region: NORTH WEST
Post by CSC1540 » Sun Oct 11, 2020 8:59 pm
Thanks Lomax76,
Tomorrow I will have a look at the plugs , that might give me an idea about the mixture .
Regards Ray
CSC Membership Number: 2130
Region: Yorkshire
Post by Jack602 » Sun Oct 11, 2020 9:02 pm
Ray,
I am running the same carb on my Pembleton, after experimentation I am running the following settings:
Idle 47.5
Primary 115
Secondary 95
Hope this helps
Pembleton SuperSport
duncans workshop March 2020 (3).jpg (294.27 KiB) Viewed 14379 times
CSC1540
Region: NORTH WEST
Post by CSC1540 » Sun Oct 11, 2020 9:05 pm
Thanks Lomax76, & Jack
Tomorrow I will have a look at the plugs , that might give me an idea about the mixture . The tick over sounds ok apart from the popping . I have tried to adjusted the idle jet but there is little movement available .
Regards Ray
Lomax76
Region: Normandy
Post by Lomax76 » Sun Oct 11, 2020 9:27 pm
Tick over is popping because of mixture too lean.
You cannot adjust the the idle jet just change the size, you meant to say adjust the idle mixture screw. This screw should be unscrewed by 2 1/2 turn after being completely screwed (not to hard to preserve the needle) From this point you can adjust the rev from this screw and the throttle.
CSC1540 wrote: ↑
CSC1540
Region: NORTH WEST
Post by CSC1540 » Mon Oct 12, 2020 3:16 pm
Hi Lomax76 Thanks .
This is where my old brain gets confused with the terminology , I have a `slow speed idle jet` which doesn't want to screw in any further. an `idle mixture adjustment screw` which I haven't touched. the idle speed adjustment screw which I have played with lots. Plus the secondary choke air mixture jet .
My plan was to change the secondary choke air mixture jet . I would appreciate a recommendation for what size to get, bearing in mind my primary jet is a 110. Sorry if I have confused everybody.
I haven't checked my plugs yet, Its raining and cold , and I have got to pull the car out of the garage to do any work.
Regards Ray
Region: Yorkshire
Post by Jack602 » Mon Oct 12, 2020 5:10 pm
Ray,
The quick win is to change the idle jet, no need to dismantle the carb.
The idle jet from your old carb may well be larger than the one fitted to the new carb.
I suggest ordering your new jets for Solex (not as Citroen) from eBay.
CSC1540
Region: NORTH WEST
Post by CSC1540 » Mon Oct 12, 2020 7:34 pm
Thanks Jack , I will try that once it stops raining . I normally get my spares from ECAS but will check out ebay .
Regards Ray
Lomax76
Region: Normandy
Post by Lomax76 » Tue Oct 13, 2020 8:14 am
Hi Ray,
Changing the ildle jet is the first things to do, Jack is right. But do not worry there is no adjustment and it must not be overtighten.
If you digue a bit on the forum there are some indication for best carb set up wrote by Ken Hanna
