Backfiring
Backfiring
Post by howardjs » Wed May 05, 2021 10:15 am
My engine; 2CV crankcase fitted with Visa barrels and heads, so valves are bigger that the 2CV.
Ignition is using a DG unit (similar to 123)
It is fitted with twin Dellortos
After the conversion with Visa barres the engine ran well, gradually improving as the new piston rings bedded in.
However, some time ago (2 years)! It started to backfire on the overrun, not the occasional pop but AK47 stuff!
The mixture looks OK, plugs a nice straw colour, and the exhaust system is new with no leaks.
I have just tried increasing the Static timing from 8deg. to 10deg. (10deg. is the recommended setting for a Visa) This has improved things a little, it now sounds like a silenced AK47 but it is still backfiring.
Any ideas?
Re: Backfiring
Post by Jack602 » Wed May 05, 2021 12:16 pm
Howard,
I am fairly confident that bigger idle jets will fix it.
Straw is fairly weak and even then may not represent the mixture at idle .
It is probably no coincidence that around 2 years ago is when they started adding ethanol to petrol that requires a richer mixture.
I had the same problem, at the same time, slightly larger jets diminished the problem, an even bigger jet fixed it!
Pembleton SuperSport
Re: Backfiring
Post by howardjs » Thu May 06, 2021 10:03 am
Thanks for that info Jack, Mmm could be as you suggest as this issue got a lot worse in France where maybe the petrol has moor poison in it!
Does you car have PHBH28BS Dellortos? Mine came from Eurocarb ready jetted for a 2CV and were OK initially.
If you have these carbs do you know the part number of the jet that improved your backfiring?
Re: Backfiring
Post by Jack602 » Thu May 06, 2021 10:20 am
Howard,
I am running a standard Solex, however my symptoms & timeline (including France) were the same as yours.
For the benefit of others running the standard Solex, after trying various jets I ended up with a 47.5 idle jet (co-incidentally also from Eurocarb).
neil curson
CSC Membership Number: 1331j
Region: north west
Re: Backfiring
Post by neil curson » Thu May 06, 2021 11:35 am
Hi Howard. As you saw on the run I have just fitted the Burton 652 kit, and they supply bigger jets for Solex carb.
Re: Backfiring
Post by howardjs » Thu Feb 03, 2022 6:11 pm
Backfiring now eliminated!
Twin Dellortos PHBH28s
Also had a flat spot from idle to 1500rpm. After consulting Eurocarb they advise fitting smaller idle jets, they sent me a pair of size 30 (the smallest). This seemed to me to be the opposite way to go, but they are the experts... this made the problem worse. So I went the other way.
The original jets were 36 so I ordered 46. This was a total success, the flat spot is gone... but so is the backfire..
Re: Backfiring
Post by notsmartcar » Thu Feb 03, 2022 9:16 pm
I’m working on my triumph bike at the moment with a Keihin carb it has an idle jet and an air adjusting screw ..an air screw has a working range fully in and to let’s say 3 full turns out if by the time your more than 3 and it makes no difference and you got popping on the over run or red hot header pipes it’s time for a larger idle jet to bring the adjuster screw into a working range of 3turns.
motomallett
CSC Membership Number: 2031j
Re: Backfiring
Post by motomallett » Thu Feb 03, 2022 9:55 pm
Hi Guys i constantly read about the problems with twin carbs on our small cc engines. I converted mine with an SU HS2 carb red spring and gg needle the car runs great right up to max revs and returns approx 60 miles per gallon. Are we trying to hard to expect miracles from these engines. Perhaps the answer is a bigger engine ???????. just another line of thought regards Roger
