Guzzi Engine Infomation.
2cvman
Region: GLOS
Post by 2cvman » Thu Jun 17, 2021 8:51 am
Hi Guzzi Guys,
750 engine Info.
Does anybody have the dimension.. Centre of Crank to bottom of the sump pan.
Weight of Engine ?
Do the have removable sump pan ?
stevep
CSC Membership Number: 104
Region: southg
Re: Guzzi Engine Infomation.
Post by stevep » Fri Jun 18, 2021 3:28 pm
750 Breva dimensions
Crank centre to bottom of sump 170 mm approx
Sump pan drops straight down away from main engine ,oil capacity 1.8 L
You can get a oil sump extension that nearly doubles the oil capacity which is good for our use, the long distance racers
Use them
That adds 50mm under the engine not really a problem with a car.
Total bike weight 182 kg , no separate engine weight in the service manual.
Keep on revving
2cvman
Region: GLOS
Post by 2cvman » Fri Jun 18, 2021 3:43 pm
Steve, thanks for the info.
Looking at replacement engine options, for a 4x4 2cv.
Extra drop at the sump, not good for a 4x4.
Has anybody maybe the racers done a dry sump setup?
